I totally lost mesh visibility
hello i’m on ipad 11 second gen, on last version of Nomad, i was moving object with gismo and then all objects vanished, even if i open an old scene or new scene i cant see any objects
Have you completely closed the app?
Try pressing the camera reset button on the bottom panel. Sometimes I have had objects disappear even when I loaded a new scene and did nothing( could have been a model scale issue) and pressing the camera reset helped. But that was a previous build of Nomad.
Also try creating a new scene with just the sphere and then load your saved scene again. It might help.
Also select object in list and try a force paint all.
thanks for the help, i tried everything you said and the situation is the same
i tried to export to be sure i still have the mesh and yes it works for exporting to blender in obj but, i’m stuck for sculpting anything now with nomad, ok i restarted the ipad and it’s working now, no more bug
for information : i tried a new same operation with gismo and resizing primitive and same size problem make same result of vanishing mesh visualisation, and i have to restart the ipad to stop the bug
So you still have to restart iPad.
If you have an object you can share that this happens to I can see if it happens with me.
Weird, you seem to be the only one experiencing that issue, at least so far.
Instead of restarting the iPad, did you try to relaunch Nomad instead (by making sure to exit it first).
What kind of operation were you doing with the gizmo (plane translate with the plane tangent to the view? etc).
Hi, yes tried to exit but when the Bug appear it’s not working.
it’s appear i have a tube using gismo to rotate change the size and live its growing toooo big for one Tiny moment and everything lost visualy i will try to screencast and send the file the if it will reproduce again, thanks to take time to help
I’m having the same issue. It’s happened twice to me now and I’m on 1.6.1. I’m not sure what causes it yet but I have to close the app and reopen.
I have the same issue, closing the app doesn’t help or any of the suggestions here, only restarting the ipad. I have the latest to date version of Nomad and ios 16.5, ipad pro m2 (if it’s relevant).
04 Dec 2023. It’s still a relevant issue. Just had it happen to me.
iPad Pro M2 with latest version of Nomad.
Turned pad off, then back on, problem solved.
Sure it’s not only solo mode activated?
I’m having the same problem! When and put my object in a big size all my scene disappear in all Nomad Projects, no restart of the app solved!! Only restarting the iPad
Still happens to me. Yes, restarting fixes and brings back the object. The disappearing act happens to me when I try and zoom with my fingers or move the object with my fingers. As soon as that happens I can no longer see any object in any file. They all will open, but no object appears. You can select tools, everything else looks normal but nothing appears in the work space. As long as I am using the pen all is good. And of course it doesn’t happen on all my files.
But in my case, if I open the file again and try to move it once again with my fingers, boom, gone again. Then back to restarting.
