Does Nomad Sculpt have the function of aligning different objects with each other with high precision like the 3D creative software on the PC side? If not, I hope to add it in a future update.
No, there is no align function, and yes, this would be useful.
Welcome to this forum.
The insert function can help though, if you want to place one object on the surface of another object.
-Select the object you want to place.
-Select transform gizmo
-Choose pivot
-Move the gizmo to the bottom of your object,
-exit pivot
-Choose insert tool
-with your object still selected, choose clone from insert menu
Now you can place multiple clones on other objects.
No replacement for align, but I helps sometimes.
Thanks for your help!
I would try according what you suggested.
Note that you can input precise value if you go in gizmo menu (at the bottom).
Thanks! That will help!
It would be absolutely awesome if you could push the values in the Gizmo Matrix with the Pencil.
