Why does it crash when I change Language setting? For example: Traditional Chinese, Deutsch..
It shouldn’t crash, it crashes for every language?
If possible check in your nomad user folder (the path is shown in the about menu, but the explore button might be broken) if there is a file named “crash.log”.
It’s possible that I’ve fixed the issue as I’ve tweaked some things related to fonts, but I’m not sure as I never had any crashes.
I found out that the problem is caused by One Drive. Thank you very much for your help.
