Nomad PC 2.3.23
Bug reports
Not able to access any settings to turn on wintab , most menu buttons not working , Win 11 24H2
intel i9-9980XE
You are using a tablet? Which one?
Did you enable wintab?
Usin a Wacom Cintiq 32”. Not able to access settings menu from top left to enable wintab. Pen or mouse both dont bring up a menu. Most menu items are not responding to clicks.
Make sure to update Wacom drivers and restart the computer.
Otherwise if it still fail, try to enable wintab manually:
  • open c:/users/name/AppData/Local/config.json
  • and change “wintab: false” to “wintab: true”
I will do that and report back. Thank you!
This setting no longer works in the latest beta.
What’s the issue exactly, the wacom isn’t working, can click or just pressure?
What’s the wintab value set in the about menu?
Note that there are some beta version available, things could be different.
Same problem, not able to access the top left menu,not able to get any response to mouse or pen from any menu item or brush, shows a cube type icon instead of the circular cursor. also json file seems to have changed, wintab is now -1 , I tried 1 but not working.
Can you try the latest beta (27)?
In case it doesn’t work, change wintab to 0 (otherwise 1).
You seem to be the only one to have such issues (no click at all).
I’m starting to think there’s something on your device that interferes with input.
2.3.27 works without any problem, settings.json has wintab on 1.
Thank you!!!
Restarted the pc now now wintab settings screen plus sculpting not working. Same settings.json.
There must be something with your setup.
Nomad doesn’t change after a restart, maybe check your wacom settings and drivers.
Hi , what would you want me to check on the Wacom Drivers ?Any logs or details I can provide you ?
My system runs all known sculpting software , Zbrush, Mudbox , Blender , 3D coat , and VR sculpting software like Adobe Modeler. I’m perplexed what is “wrong” with my system .
You said it was working but then not, but Nomad doesn’t change after a restart. Sure you are running the correct version (latest beta 27)?
And so far you are the only to have such issues (no click registered at all even with mouse, etc).
settings.json has no wintab option, only config.json (users/name/appData/local/Nomad Sculpt/config.json). But normally you don’t need to edit it by hand.
Clicks are registered on some menu items . Not all, the left top settings menu doesn’t respond .
I’ll possibly record a video for you to see this .
The first time I ran .27 it started working without any inputs from my side. I meant config.json, my mistake.
