New Wacom MovinkPad Pro 14, pen input is not working
Bug reports
Just got myself the new Wacom MovinkPad Pro 14, touch is working but as soon as you use the pen ( Wacom pro pen 3) no inputs work, i.e touch and pen?
Is this the android one? If so, Android prevents simultaneous usage of pencil and touch, it’s a hardware thing.
In any case if you have more input issue I can add you to the Android beta, I tweaked a few things input-wise in Nomad (pencil button, etc)
Hi yes its the new Android one, just released. yes if you could add me to the beta that would be great.
Could you add me as well please? Same issue and the sphere just floats up constantly. On demo version, movinkpad pro 14
Hi thanks for adding me to the beta, this seem to have fixed the issue, I will do some more tests over the weekend.
This fixed my issues as well! Thank you, i will also test and update.
same problem would love to get the fix also
Just wait for next nomad update on android, should be soon.
Same issue on my new Movinkpad 14 pro as well..
Same here… is there still hope getting into beta or should we wait for update? thanks!!
Ok I added everyone but I’m more interested in the “crash on save bug”.. Any information would help.
  • does it crash on other scenario (rename an object?)
  • Export nom vs export render
Mine is crashing on a normal save, export is fine.
no long save names. and only one object just the sphere.
But does it crash when you rename an object (scene menu)
yes it crashes when I rename the object also.
Can confirm, in beta crash on save. Before beta, i was able to save (even though inputs were not working) i could still interact w UI and save, modify settings etc
I was mislead by the saving thing, the issue is just the name popup. When you save a new project it will ask for a name that’s why it crashes.
something you can try until next update: in interface menu enable “nomad dialog” and see if it works.
cool, that appears to work! also saving existing files also works, in case that was a concern
Yes that works
The new update, seems to have fixed the saving and renaming scenes issue..
I’m currently testing the new Wacom tablet on my side and I’m experiencing the same pen issue that other users have reported.
Would it be possible to grant me access to the beta as well, so I can test and provide feedback on my setup?
Thanks a lot for your work and support!
