My wishlist of 2 requests
First, I have to say Nomad Sculpt is such an amazing app so thank you for its’ creation.
My 2 feature requests are:
  1. To be able to create a layer that can use the gizmo tool. That way the layer slider can be used to show the movement of part of the object.
  2. A menu to store different UI configurations. So for someone who wants to say make a tutorial but has customized their UI, then can switch back to the default one to avoid any confusion.
Thanks for reading!
  1. Change Target mode to vertex then the gizmo movement is stored on the Layer.
  2. Locate a 2. Nomad on a other MAIN Folder then you have the default UI.
    You can switch between the versions without problems.
Thank you so much!!
For the UI simply save a project, the UI is saved in every project saved.
To load the UI when opening a project, simply check “keep gui settings” in Files → Advanced (Import).
Thank you!
