Mirror in Nomad
My Nomad mirror function is broken. It doesn’t reflect correctly; it reflects from the other side. The mirror drawing function doesn’t work either. I have a large distance between two dots, so I’m only drawing one. How can I fix this?
Go into the Symmetry menu and check a couple things:
Local vs World
Which axis is enabled
You can enable Show Line and/or Show Plane and should be able to see where the symmetry line is. Play with the setting is mentioned above and it will change the symmetry line. Then you can see where it will mirrror.
