Material ID view, crash
THE PLATFORM: iPad Pro M4
NOMAD APP VERSION: 2.12.1
Hi, I don’t think I understand if Material ID display works properly as it seems to just show different colors for every different object, keeping same color for instances… but not same color for objects that share the same material, it doesn’t seem to do that as I thought…
…anyway, I actually post to report the app crashes when I select Material ID and then later select Object ID (or touch the Randomize ID)
You can ignore this option, it should not be exposed.
I also added a “Curve edit” shortcut button down there to test it but I don’t seem to find it does something. :sweat_smile:
