I discovered this morning a very small problem of logic but nothing serious. I select an object I activate the gizmo I constrain the rotation to 90 ° I rotate, I take any other sculpting tool then I select a light that I want to rotate this one remains constrained at 90 ° however the constraint option does not appear since you have to reselect “gizmo”. Wouldn’t it be easier that as soon as we select the lamp we also have the option of constraint display and perhaps also be able to control the intensity of the light with the slider? Thank you
Topic | Replies | Views | Activity | |
The three fingers in 1.91/1.92 cannot rotate the newly created custom light source | 4 | 95 | December 15, 2024 | |
Locking light target (Quality of life) | 0 | 144 | November 13, 2023 | |
The main model should rotate, but the surrounding models .... fixed and the scene and light ? fixed | 8 | 642 | March 12, 2023 | |
Rotating object by a exact degree | 3 | 4183 | October 15, 2020 | |
Lights gizmo axial movement arrows | 2 | 339 | September 8, 2021 |
