Larger or customized size of thumbnail in open/ save window
Hi.
I really enjoy using this app.
Is it possible to make the thumbnail of the files larger or have the ability to resize the thumbnails so that the preview is clearer and the name of the file is more visible and readable?
In few words a better file manager in Nomad.
Thank you.
Hey there!
When you select the Open button, there’s an icon of 4 arrows pointing outward that’s next to the Red X, that expands the whole folder. I just found that a few days ago myself.
Hi my friend.
This button resizes only the window.
The thumbnails of the files remain the same.
But the name of the file is cut at the end and the only way to see the whole filename is to press the rename button.
If there is a way to make the thumbnails larger then the full filename will be visible.
Or maybe a list of the file with thumbnail and filename.
Oh ok, sorry that didn’t help. Hopefully someone has a solution for you.
