Objects are reflected incorrectly through the glass facets of the tube. It looks as though we are not seeing the objects themselves, but rather a view of them from below, as if captured by a camera. Furthermore, the object shaped like an ingot appears to overlap the object in front of it, even though the ingot is actually positioned behind it.
Could you provide the nom files?
Yes, sure
вт, 27 окт. 2026 г. в 23:38, Stéphane Ginier <notifications@nomadsculpt.discoursemail.com>:
I asked for access. (nomadsculpt.discoursemail.com is the forum sender email)
Confirmed access
The ingots are using refraction material.
Use “opaque” instead.
Real-time refraction has lot of limitation.
