Imbed Settings for Brushes?
Is there anything like the Depth Imbed setting for brushes similar to what’s in Zbrush? I ask because I usually use a clay buildup brush there with an intensity of 10 and and Imbed setting of 8 which allows me to sort of blend by adding and cutting without having to use any smoothing which I prefer not to do in most cases. If anyone knows of a way for me to achieve a similar result in Nomad I would greatly appreciate it.
On a different note, I’ve noticed that when I use the insert primitives brush on a new project they are much larger than the sphere it starts off with. Is that the normal behavior or is there a way for me to adjust that?
Thank you!
