As title says, the ‘my project (count)’ is good as a temporary name, most of the time I start with a sphere without knowing what it’ll end up being, the rename box kinda gets in the way. Manually rename a project at a later time is very easy and more to-the-point with the visual thumbnail.
I don’t think it’s that big of a problem unless you create a project every 5 minutes
But there also another reason why there’s a popup : you can’t rename project in Nomad for now.
Renaming the file directly works as well but it’s not the intended way.
I need to add an option to rename project in Nomad directly.
That’s true I just realized there’s no direct rename function just yet
I’m lazy instead of managing objects I like to hit the new project button every time I do a new draft
