Hello please it’s been a week since I can’t find how to put my image on the full yet I put invertpixel and lock radius
What is the manipulation with the finger to remove the mask
Not easy to help - because I don’t understand your question at all.
What is the manipulation with the finger to remove the mask - what does it mean ?
There is no mask on the mesh…
But I guess what you want to do…
If you want to stamp the animal as a mask on the plane:
Change Mask Tool settings:
lock radius mode - flat falloff - no pressure
Increase Plane mesh density - e.g. 4 times multires - about 300000 Polycount or more
Turn off symmetry
Then stamp the mask…
And your image is not optimal it’s not complete black white… but it should work if you press sharpen when the image is applied as mask …
