How to bend plan or box
is there any way i can draw a path and create plan or box with circular effect or paper effect
721a535454797094b88e0f1b9fbe53c7
f4dc2c65cc112f134ee5f6000ce0052a
want to create similar this kind of plan
Regardless of what “box” or “plan” are you referring to. Based on the image you’ve attached, and what you have said.
Maybe you can use tube tool with a “flat” profile like this
Then apply some twist if nescessary
can you pls create a small video if possible i am newbie
Choose tube tool.
On left menu choose curve and go to side view (perspective off. Tap on navigation cube to switch to left or right view)
Now choose “profile” in top center tube menu. Drag all points to middle left and right and uncheck “closed”. When you drop one point onto another it is deleted.
Now you see two colors of your stripe.
Go to “gear” menu and uncheck “coloured backface”
If you want to twist you sheets, twist is up in tube menu as well, same is radius to define width.
Maybe you want to increase division X to have more polygons in tube menu.
When you are done with basics, best is to clone your object in scene menu (top third icon from left then clone) to have a backup. Hide your backup and validate your tube (after validation no way back - > therefore backup :wink: )
Now you can use the mov tool with big radius to make final adjustments.
Good luck.
I’m sorry if this is so quick but the forum allow only 8mb for uploading a file(s)
thank you so much got it
How can i make it traingle instead of rectangle …i want to make a triangle handkercief
