How do I create low poly models in nomad?
Is there a tool that allows me to do this or would something like cozyblanket be a better option for building my low poly models? I like the way I can do this in 3d coat where I can literally just draw my quads straight onto the high poly model.
Doing it within nomad seems to yield a fairly random end result with the way the topology turns out. Quad remesher seems more accurate, but I still don’t think it’s perfect.
Also, if I did go the cozyblanket route, how could I reimport the low poly mesh with uvs back into nomad with my high poly sculpt?
I’m fairly new to nomad. I’m more used to 3d coat.
I guess you could decimate a cube down to about the number of polys you want and then move them around. Or create a high poly and re topologize using the quad mesh set to 50 instead of 10k
