I know it’s only supposed to be a Debug Feature, but could you consider adding “sliders” to the debug height map, in order to set the distance start and end point of the depth gradient? I’m starting to use depth maps while having fun with Ai images, and being able to customize the depth map woould be so useful! At the moment you have to resize and move the elements around in order to have a useful gradient…
Not sure if you are on 1.80 but there is a focal slider at the top.
Otherwise maybe the postprocess tone mapping and color gradding are enough to control the depth range?
OH I hadn’t seen the focal slider! That’s exactly what I needed! Thanks!
