Gizmo + World Size / Sizing Error + Solution
My version was heavily decimated because I was on my iPad Air 4 (only 4gb of ram). I can do it on my desktop but I’d prefer if you manage to do it yourself.
According to your screen you didn’t scale down.
What is happening after you scale down? (Screenshot, or video)
Make sure to write 1.0 and not 1 (otherwise it’s going to do an integer division), the real value doesn’t matter much, you just need to have the order of magnitude correctly.
Also after it’s done just click on the cube to recentrer the camera, then save and restart the app.
ps: note that in some case Nomad decides to transform the vertex instead of the matrix. It was typically the case in my video. That’s why after I entered the value I didn’t have to « bake ». It depends on the value you enter (most of the time, only the matrix should be edited though).
