After trimming, the finger gestures no longer work. Double tap for UNDO no longer works and the cube for the views can no longer be unlocked. Sorry on the View Cube the NORMAL Finger Tap does not work.
Try Trim / Sym on / use Polygon.
After trim - try 2 fingers UNDO - it doesn’t work for me anymore.
The VIEW CUBE also no longer works.
The same happens with the split function / polygon.
It has nothing to do with the Apple Pencil.
It is a repetitive problem.
Polygon mode overrides the 2 finger input because it’s using it to transform the shape.
The behavior is the same whether there is a polygon being drawn or not.
It’s not a bug, it’s by design. Moving it as feature request instead.
