Hello i just bought the nomad software and i wanted it to deform the face asset of spark ar… which worked great in nomad (first steps i am new in the 3d field) – but when importing it as a deformation into spark ar – it didn’t work. I could import it but it didn’t serve as face deformation – i tried as obj and as glb… but no success… what would be the correct way or what could i do to make it work? Any help appreciated… thanks and sorry for my english…
Before loading the Spark AR mesh, go in Nomad Interface menu and select “keep UVs”.
Then load the face, sculpt it and export in OBJ.
It’s a bit experimental.
[quote=“stephomi, post:2, topic:1417”]
[/quote]?
… where can i find that…?! my search was quite successless…
The Interface menu is the icon on the top right (with interface settings).
Scroll at the bottom and click 3 or 5 times on the « dev » button and you should see new options.
thank you very much! worked out!
Hello stephomi, thank you for this tip, it was extremely helpful. Is there a way to get it to work with multiple layers?
What do you mean by that?
Layers as objects or actual layers? I don’t know much about AR Spark.
