Everytime I export FBX, it exports the FBX, and closes on its own(crashes). I would have to restart Nomad everytime I export an FBX. Any idea on what I can do?
This is how you can recreate it - New Project → Export FBX → Choose any location → click export.
Doesn’t happen to specific Nomad files. It happens to all Nomad projects, so it doesn’t make sense to send you a project file. Let me know if you need anything else. Thanks.
Are you using an arm64 based windows?
I forgot how old is 2.9.8… is there a “compressed” option in the fbx export option?(along with binary vs text).
Just wondering if certain combination works.
Good idea. This helped me understand that the issue comes from using Ctrl+E to export. I set the shortcut as Ctrl+E to export FBX. Doing that crashes. And I also found out that I dont even have to click export. If I just press Ctrl+E and press Esc button, it still crashes. Using the UI doesn’t crash. Also, is there a quality reduction in the export if I use compression on?
