Hiii! I need help with my exported image slightly changing how I’ve set up a scene while working. I’m not sure what happened because this wasn’t happening while using the app earlier in the day. Maybe I’ve changed a setting. I’ve tried both perspective and orthographic views, same thing. (The pink sign should be covering the other sign in real image)
It’s because of the aspect ratio you’re selecting for export, combined with the use of a reference image… Try selecting “screen” for your export resolution.
Alternatively, map your background image to a plane. There will be no distortion when exporting at any resolution or aspect ratio.
It’s a bug.
Thank you!
Thank you!!
