Below the primitives menu in the “add menu” (I think that’s what it’s called), a new menu section could allow quick access to objects you’ve created and pinned to this Object Library. This would allow you to insert objects you frequently use into your scenes with a single tap. They don’t have to have all of the options primitives have, but the Object Library could be a fast way to import objects into your scene instead of having to navigate through your file system. This would help if I create several similar sculpts. Say I want to sculpt characters in separate scenes regularly. I use the same base “person” object, and then just sculpt different clothes and facial features, hair, etc.
Topic | Replies | Views | Activity | |
My own primitive s from objs | 7 | 764 | March 27, 2022 | |
Bottom Shortcuts / Bindings - Add Primitives | 5 | 69 | April 25, 2025 | |
Object Instancing | 6 | 1460 | February 9, 2022 | |
Drawing in primitives like a brush tool | 7 | 1071 | April 4, 2022 | |
Primitives | 1 | 242 | September 12, 2023 |
