THE PLATFORM: iPad
NOMAD APP VERSION: 2.8
Hello great creator of Nomad,
Here are couple issues I’ve experienced and worthy for your attention. When I click Save in the Project menu. When the window pops up, and the amber/yellow button is displayed with “YES” Ive noticed that the button itself is not protected and the selections that are displayed behind the Save Banner are also active. So there are times when I click YES and it asks to RENAME or DELETE the file. If I click on the YES that is between those selections then it rightly applies the YES function. Please let me know if you understand the above and if not, I can try to add some pictures and a different explanation.
The other issue I’ve experienced recently and it’s happened several times is the Quad Remesher add on that I have purchased will sometimes display as if I need to purchase it. I have tried closing down the app and reopening and it still displays. It usually resolves by itself without logging out but it happens enough that it is becoming a problem.
Thank you.
