Close hole in curvature
Hi all,
I’d know if there is a way to close an hole in curvature
In video the classic hole repair.. in photo the repair that I’d like to have.
Thx for help
Angelo
No, there is no such option.
There are some algorithms than can do that but I suspect they are tricky to implement it robustly.
Tnx for reply. I understood. Maybe, if can be a suggestion it will be possible
To create a bridge before close a hole (to drive the algorithm) or a tool like “cut and fill”
You’re absolutely right—some kind of tool or solution for these small hole-filling or bridging problems would be extremely useful.Unfortunately, that doesn’t really exist at the moment. Maybe it will be added in the future.
For now, you have to improvise a bit. My usual workaround is to mask a small part of the mesh, then use the Gizmo or Move tool to pull it outward and slightly enlarge it - this the bridge. :grin:
After that, I cut away the excess using the Trim tool. This closes the gap, and in most cases it’s perfectly sufficient.
Maybe this approach helps you as well.
It also works with a mesh with a hole - mask the border of the hole → then drag the mesh that it is large enough to trim → then the trim closes the hole and the mesh is complete again…
Like this example:
Very nice workaround! Tnx so much
