This is just a quick message to anyone finding the gizmo harder to use in version 1.71
I believe that by default in version 1.71 the gizmo is set to “compact”, which is probably good for anyone on a smaller device, but can make it a bit fiddly to use sometimes.
If you preferred it how it was in previous versions when it was a bit bigger and more “spread out”, just go to gizmo settings and untick “compact”, and it will go back to how it was.
