ViZeath
When I decimate the object (body) I mask the lips area to protect the lipstick. It still looks good after UV unwrap.
But after color baking, this happens.
Before:
After:
When I use Blender for color baking, I get the same exact result. What should I do to fix this?
Steve
Do you have the head and full body mesh on a single UV? If so that will be due to pixelation as the mouth will take up such a small area
Try keeping the head to a uv of its own
Texture resolution is simply too low.
Or the UV around this area should be way bigger in the texel space.
You don’t have that control of UV control in Nomad though.
ViZeath
4
Thank you for advice, I tried baking in 4k and now it’s working fine.
