Box primitive inheriting previous box scale
Bug reports
-When I add a new box (not validated)
And scale it down
Then add a new box
The new box will be scaled down as the previous one.
-It’s only happened with the box primitive .
-Also if I add different primitive after I scale down the first box
The second box will be fine.
Nomad sculpt V 1.47
iPad Pro
It’s not a bug, when adding a primitive it reuses the parameter of the currently selected primitive.
But when I try it with cylinder or the sphere
It didn’t
Is there is
An option to enable/disable it?
I tried it with cylinder and it does work, not sure what you tried.
No option to disable it.
Ok I understand it now
When I add the cylinder I scale it down on the x axis
Which is don’t have a slider on the cylinder primitive setting that’s why it wasn’t applied to the next cylinder.
But if I scale it on the y axis which is the height slider on the cylinder primitive setting it will apply to the next cylinder.
