Please don’t enable 120Hz, I use Nomad on both an iPad Pro and on my Air 4, I actually prefer using it on the Air because battery drain isn’t as fast (A14 uses 7W P/H vs M1’s 16W + less intensive task use) - and the screen refresh rate is identical on both the Air and Pro in Nomad. 60Hz is perfect territory in my opinion.
@Mr_Risle Probably one of the most important things to consider also is where you’ve already made your nest. If you’re shored up and comfy in Googles services - it might be sensible to remain there. Apple offer superior technology at the heavy cost of being encapsulated entirely in their enclave. Once you switch your digital lifestyle over to them, everything suddenly becomes proprietary. Apple technology doesn’t play well intentionally with others, and vice versa. Music services for example, has to be Apple - if you use others, you wont get full access to the iPads audio capability - thats just for starters. USB-C accessories that might have worked fine on other devices, might suddenly seem restricted or just unusable. Apple offer superior proprietary technologically, but at a heavy cost to your wallet - there’s lots of small additional costs you find rack up when being with Apple, dropping money on the iPad is just the beginning. When you’re with Apple, they want you to go full hog on their services and do their damn hardest to shoe horn their consumers into doing so. Hope this also helps influence your decision.
