UV Unwrap Not Working
Whenever I click the uv unwrap button, it hits 100%, then shows nothing. I assumed it just wasn’t showing on Nomad. But then every time I export it into Procreate, the UV’s aren’t showing in 2d texture mode on Procreate like it does for other models I’ve done this with in the past.
Have you checked the UVs using the inspector? Long press inspect on bottom menu, select UV and you should see coloured UV layout preview.
As for procreate, I think you need to paint the whole layer before it will show you the 2D layout (it’s been a while so I may be wrong)
thank you! painting over it worked
