Hi there, I am a novice here. First of I love this application, a lot to learn because I come from CAD background. Lot’s of fun though.
However I have a question, when you have 2 mirrored object I can’t seem to find a way to loosen the mirror function I want to position one of the two objects in a different way. Is there a way out here?
Just below the list of objects is “Separate”.
Thank you so much for the tip Spork, much appreciated.
You could also use the split function and select the object you want to split. They will be seperated then. But watch out, i think Multi Res will be lost then.
Hi ToBe, I am gonna try that also, good to have differs options.
Thanks a lot.
