Hello, Nomad community!
I’d like to thank everyone for the inspiration and clear explanations that have helped me in my work.
And of course, a special thank you to Stephane for his patience, consistency, and dedication to perfecting every little detail.
The environments and assets for two full-length animated films were sculpted and partially modelled by a single person, entirely on an iPad.
Everything is fast, convenient, and intuitive.
Thank you!
Since you’re working with full environment assets on an iPad, how do you manage scene organization and performance? Do you keep separate Nomad projects per asset and combine later, or build larger scenes in one file? Any tips for keeping sculpting responsive as scenes grow would be helpful.
The animation studio works in Maya, where all the large scenes are assembled.
My workflow in Nomad is: sculpting → Decimation → Quad Remesher. I then refine the topology after Quad Remesher, either in CozyBlanket or on a PC.
This gives me two versions of the model: high-poly and low-poly.
I did almost all of my work on an iPad Pro M1 with 16 GB of RAM. I was comfortable working with scenes containing 20–40 million polygons.
Now, on the new M5, I can comfortably work with scenes containing 50–70 million polygons. I have post-processing, Ambient Occlusion, and high graphics settings enabled.
I mainly work with relatively small assets, usually up to 30 objects. As soon as I consider a particular part finished, I decimate it as I go.
And yes, I leave the very fine details for texturing. I don’t sculpt them.
Use Groups! Give your groups clear, descriptive names.
Turn off post-processing - If Nomad becomes unresponsive.
I’ll send an example of an asset showing approximately the size beyond which working becomes less comfortable for me.
But if you zoom in on, say, the staircase, you’ll see a lot of detail.
