One thing for the snapping would be nice - if you set a negative offset ONLY 1. NODE snap NEGATIVE.
e.g. If you draw the curve for a hair / fur you need the 1. NODE as a root inside the other mesh (so a negative offset)
BUT the other nodes snap on surface with 0% offset.
So if you try to let hair GROW out of the head and snap to the head skin it doesn’t work…
So: FIRST Node snap NEGATIVE all other NODES snap 0% …. Maybe there could be a solution for this…
At the moment you have to use 0% offset & snap → then manually turn off snap and put 1. node by hand inside the other mesh.
