Trimming character
Hey guys, is there a way to trim the bottom of your character? I feel like I’m trying to eyeball each section to be flat basically trimming the bottom of the character. Is there a way to trim everything all at the same time with the ruler evenly?
Thanks,
Steve
Not sure if this is what you’re wanting but when trying to trim an object to be flat, I use a box. Scale & move the box to cover the objects you want to cut off, then boolean subtract the box from the object. If there are multiple parts I need to trim at the same spot, just clone the box once it’s in place and boolean each object with a cloned box.
Ah I see, that makes sense. Thanks
