The virtual keyboard no longer appears
Hello. I’m having a problem with Nomad Sculpt after an operating system update. I should mention that I don’t have a physical keyboard connected to the tablet. When I want to enter a number, for example, a cylinder diameter, the virtual keyboard used to appear on the screen. Since the update, the virtual keyboard no longer appears. The handle “numerical input” is activated in nomad. The virtual keyboard appears normally in other applications on the tablet, except in Nomad Sculpt. Can you help me?
My system : Lenovo Yoga Tab Plus - Model TB520FU - Lenovo ZUI 17.5.10.036 Version Stable - Android V.16
If you rename a mesh, is it working?
If you click on the number in the multiresolution slider or any color text input, is it working?
No, it doesn’t work. The keyboard has disappeared from Nomad. I installed another keyboard app downloaded from the Play Store and set it as the default keyboard, but it doesn’t work. It works in all the other apps on the tablet, but not in Nomad.
Well I don’t replicate on any of my Android devices.
I’ll update Nomad today, I think I know the issue (can’t verify though). You can check the Google play store for nomad update the following days.
Hello Stephane. The keyboard works again but I have to uncheck (Use Nomad Dialog) for it to work. Merci ! for your help !!!
