The paint all feature only uses default color
Hello,
When using the « paint all » feature the painted object is always painted in yellow color which is the default color from the color picker. Changing the color setting works with the paint brush but not with this button. The problem is present since the update of the 30/01/2025. It is affecting all my projects. Is there a way to fix it on my device?
Sincerely,
Did you check the change log? It may have the issue listed. Click HERE to read it.
Thank you for the quick answer but the 1.97 isn’t on the Apple Store. Do you know when it’ll be released there ?
As soon as it gets approved by Apple?
You can see the change log and when Steph posted the next version he’s working on. In this case v1.98 was posted 21h ago as if my writing this.
When he posts a new version number (1.98), that generally means he has submitted the previous version (1.97). Updates take a day or two depending on Apple.
It’s under review.
I’m having the exact same issue.
the same thing is happening to me even if I change a color in a previous project when I hit “paint all” the color defaults to a mustard color and not the color I’ve selected.
same here, I thought I was going crazy. Every time I would use “paint all” the color would show up as Im using it but as soon as I hit “paint all” the color defaults to a mustard color. Even when I change a color on a previous project, the same thing happens. Hopefully they fix this soon.
Read the entire thread. It tells you a fix is on the way :man_facepalming:
My menu does not look like the screenshot … I can find the paint all button but under that is the colour selector ?
Found it. It’s in the upper bar
Glad I’m not the only one with this bug it totally made me think I had a setting wrong accidentally like I tapped something by accident ’
