Symmetry Menu - split & mirror -> only a split option on the symmetry plane
Is there actually a way to use split mirror in the symmetry menu to obtain two meshes? As separate meshes: 1. the split mesh 2. the mirrored mesh → not merged! I need a split on the symmetry plane … :wink:
Not possible indeed.
For simple axis aligned symmetry with a single plane you can use the split tool with polygon and snap.
Otherwise if I were to add the feature it would need to handle multiple plane for consistency, potential creating 4 or 8 meshes.
In that case it could be an extra “separate by mirror” option (without necessary applying the mirror, but I don’t know if that would be useful)
Thanks for your reply.
Yes, separate by mirror sounds better.
The intended use is, for example, for picture frames or tube profiles, etc. – I can think of many use cases …
In my opinion, it would be a useful option.
I have often been asked how to cut a mesh precisely along the mirror axis… here is one way to do it.
Hello, good evening. I have tried the desktop demo. It would be interesting if we could have in the final version, the pop-up windows not fixed, because in my case I have two monitors and it would be great to have them on one monitor and on the other the image we are working on. Thank you very much and congratulations for this work that is about to come out.
Ajubel
www.ajubel.com
#ajubelstudio
