Symmetry issues with tubes
I’m having symmetry issues while using the tube tool and multiple profiles. I’ve tried several variations, but the problem is consistent. For example, if you create a closed 4 point B-Spline path (circle) and use the same profile for the left and right points and a different profile for the top and bottom points, you’ll notice that the shape is twisted. I tried creating the objects from both the top and front orthographic views using grid snap. I was also careful to make sure “twist” was not used.
It seems to be a strange unintended behavior, although I’m not 100% positive. Does anybody have any insight into this issue? I have several symmetrical designs. I would like to build using the tool but with this twisting issue, it’s impossible.
Any suggestions or workarounds are greatly appreciated!
Thanks in advance
