STL/OBJ issue exporting (beta 1.91)
I have a model composed of many meshes, I select one by one and export to STL or OBJ, some meshes when import into the slicer maintain the scale and others the scale is exaggerated bigger.
All the meshes have the same scale in Nomad, join, remesh them has no effect, ones are correct and others are bigger.
What I’m doing wrong or missing?
Attach capture, one of the issues is with the select mesh.
Only idea I have if they have the same scale in Settings->Gizmo. In case they’re part of a group, also check the scale of the group object.
Hmm, it shouldn’t happen.
Transform is baked anyway for STL/OBJ, and selecting a mesh inside a hierarchy should work as well.
Having the file could help, along with which object to select to replicate the issue.
There is one thing not supported yet: if you select a “repeated” node it won’t work at the moment (instances generated through a repeater node)
I repeat the process, checking the scale, out of any group, something happens.
This is how appears in Bambu Slicer, I just sent you the .nom by message
I don’t replicate the bug.
To clarify, did you make the test « export from Nomad and re-import in Nomad »?
If you only export from Nomad and open it elsewhere, then the issue is 99% elsewhere (your slicer).
You can open your stl/obj elsewhere (blender, etc) to verify that it indeed works.
