Problem with Decimation
THE PLATFORM: , Windows
NOMAD APP VERSION: 2.12.1
I’m having a problem with Decimation.
Before, when I used decimation, it was smooth and smart — it kept sharp edges and detailed areas dense, and made polygons larger on flat parts.
Now, when I do decimation, all the triangles end up being the same size and density across the whole model. It doesn’t seem to recognize sharp corners or smooth transitions anymore, and it ruins the model’s shape and quality.
Could you please check what’s wrong or tell me how to fix this?
Thanks!
What settings are you using for decimation?
Sure you are in the correct menu? What’s the uniform faces value?
Maybe show a screen before/after.
