Poly editor  PLS…
We need this
Have you tried Vakence 3D on iPadOS ?
How is it ? Does it synergize well with Nomad ? I’ve been on the fence about Dropping 35$ on an APP
I have to admit i refunded it, but only because I only used it on iPhone. I will buy it again on iPad now I have my new one.
It’s a modeller with the same sensibilities as Nomad. Reasonable UI, decent features - being actively developed. It did what I was expecting but it found iPhone to be a bad platform:
Also….inports well to Nomad.
Maybe you can use blender instead. If you are an Android user, you can try the cracked version of the 3D modeling APP(APK) website.
Way too expensive…nearly 40 €.
Autodesk will probably charge 50 a month for zbrush for iPad …. 30 dollars to own an app is a steal… penny wise pound …… you know the rest…![]()
It’s very inexpensive if you compare it to other software, but not ready to be used. It crashes and there are important tools missing.
Uughh that right. There’s a high chance that ZB for iPad will be subscription based. That makes me sad.
Not only that, I’d say there’s a high chance that Zbrush for iPad will only have the feature set of ZbrushCore. If so, then isn’t Nomad already better?
Autodesk. Lolz
