Pen and pencil tool for Nomad Scultptor. Alpha brush avaialble?
Alpha brushes are great but fine I am struggling creating fine lines for details (eyes) and portrait work. Sketching is good example.
Thanks
You need to up the mesh resolution locally to the areas of detail. You can use dyntopo & “paint” a higher resolution using the clay brush set to zero intensity. Turn on mesh visibility so you can gauge how high you need to have dyntopo set to.
You can also do a custom falloff for your brushes too, for narrow strokes I like to use the crease brush and give it a very steep sharp falloff
Thank you for the tip. I will try that out today.
Do you want to “draw” fine lines on an object - that is, paint sharp lines - or sculpt the fine lines like skin wrinkles…?
