OBJ export to Procreate splits mesh into layers
I’ve unwrapped my model (single mesh) from Nomad and imported into Procreate and it breaks up the mesh into a million pieces.
I couldn’t find a solution to this anywhere. Has anyone else had this issue before?
In the obj export options, maybe disable “face group” or “write objects”.
I’ve already done exports with one unchecked, then the other, then both.
Unfortunately the issue persists.
Maybe Procreate will fix this in their V6 update early next year? They haven’t touched the 3D painting since it was released 5 years ago!!
It should definitely work if you disable face group.
Otherwise you can always try usd export.
USD worked, thank you
