Not A Bug; SelMask Query
Hi stephane, just curious as to why this happens when I use SelMask - using the rectangle and highlighting a few polys (yellow perimeter) on chamfered edges selects a bunch of other neighbouring poly’s as seen in the screen shot. It works fine on non-chamfered. I understand this is part of Nomad, but it confuses me why it does this - if I understand the cause or process as to why, then I can work around or find another solution, thank you.
Update: using regular Mask and manually doing it per vertex I get the results I’m after - why can I not do this with rectangle?
Maybe Symmetry?
Jep, symmetry is on on top example. Very likely to be that easy.
Thank you Stephane and @knacki
