I have objects that I mistakenly enlarged with one example normally 140mm in length to 80,000mm in length along with a newly added primitive box of 1mm. When I try to scale the huge one back by 0.00175 the object disappears (microsized???) and no amount of stretching lets me view either of the objects. How do I get the view and grid to display these two objects which I hope are close to the same size?
By the Viewcube there should be brackets like this:
Tap it and it will zoom and focus on the object you have selected. It’s likely that you’re scaling it too small to see it from the original view.
Thank you! Part of my difficulty was that I tried (unsuccessfully) to scale multiple objects and that didn’t work, even those in a hierarchy. Not till I joined objects, scale down, then separate (with all the carefully-named object labels gone).
Then, it took some time by trial and error after the successful scale to bake the objects back to 1.
I really couldn’t find in the docs the difference between the icon and the house icon. They seem to work the same.
