While using Nomad Some glitch happens and the entire pc gets very laggy. Not slow but its like 1frams per 10 sec. If i click any button in nomad or even any action in pc like pressing the window button to open the start menu will take 30 to 40sec. Even closing nomad is not fixing this and i have to restart the pc. This happened twice and I was not able to replicate the error intentionally.
The scene is also not very heavy. I was learning how to use the nomad sculpt with the default rounded cube. This is a serious issue as when this happens even restarting the pc is hard as everything is slow.
Okay I was actually able to replicate this error. Sorry for the awkward video angle i recorded. I was recording this footage alone I remembered this crash happened while i was using the ctrl + shift key for tool. So while using the hide tool either deleting the face or quickly inverting what is visible is causing. As you can see in the video not just Nomad sculpt but the entire pc was crashed. I have to hard reboot my pc. Please fix this issue and release a patch addressing this as its not just Nomad but the entire pc is at risk because of this bug.
Also want to mention just in case, I have a decent powerful pc, I7 14th gen, RTX4070, 32gig ram & the main disk is a SSD. The video is quite long. The error around 40seconds into the video. Before that i was just quickly hiding and unhiding the mesh.
Yeah it’s bad, thanks for the video.
I’m trying to replicate the issue but so far failed, I’ll try later on windows.
I’m not sure exactly what triggers the freeze (ctrl/alt, invert, delete hidden, etc).
Yeah it’s hard to replicate, that’s why even in the video it took some time. But it’s something have to do with the Ctrl+Shift key. If it’s just a nomad sculpt crash i dont mind testing more to replicate and pin down the issue. But because it’s crashing the whole pc i dont want to replicate this often.
I am also experiencing this issue. Just baught my first license on the PC and when I started sculpting or using Nomad, It just lags. It dosnt show that nomad is using much CPU usage nor RAM. Updated to windows 11 just 10 minutes before activating nomad sculpt license. After using Nomad for a few minutes everything starts to Lag like crazy. Computer Specs: CPU 12th Gen i5. 16GB Ram and a GTX 1660 Ti. Trying an “sfc / scannow “ on CMD & driver update. Maybe it’s a windows thing and not with nomad? Will send feedback if this works on my end
Latest version?
Is the polycount high or it’s just the default scene?
Is there errors in the logs (Debug menu, top right, → Logs)
You can try changing the GPU (“low power”) in the about menu, but I don’t think it’s going to change anything.
Issue: Windows 11 will lag or freeze when running nomad sculpt 2.9.8 (even after clossing nomad sculpt)
Trouble shooting done: Restart, Hard reboot, CMD “sfc/ scannow”, driver update for GPU, reinstalling nomad sculpt, installing on another admin account on windows, Changed NVIDIA settings for Preformance over Quality, Change Power setting on Windows to “high performance” (Thinking my hardware may be under powered), Lastly I FORCED UPDATED to Windows 11 version 25H2.
No errors in the logs and would still lag with the setting changeed for the GPU to “low power”. It still had the glitch where the whole system lags until everything freezes.
The last 3 things I did somewhat Fixed it? I dont know why Windows act up while running nomad sculpt but doing a forced update worked for me as of this writing. For anyone who has the same problem, you could try what I did.
Sometimes your Windows device would say “You are up to date” but go to settings and click that “check for updates” botton. You would see updated available, just download and install then restart. Check for updates again after restart even if it says your device is up to date.
To Stephane, I love nomad sculpt when I first got to use it on a Galaxy Tab. Love it soo much I saved up and bought an ipad air and nomad plus quad remesher last year. PC version is as wonderful and user friendly. Thank you for giving us artist specially from 3rd world countries this wonderful and affordable tool.
I’m currently having the same problem as you had, my Windows 11 updates are all up to date, so I don’t think that’s it. Do you still have this problem happening at all from time to time? What drawing tablet are you using? I’m using an XP-Pen Deco Pro Gen 2. As far as I can tell, it doesn’t happen when the tablet is plugged in, only in Bluetooth mode (could be wrong, but from my testing there has been no lag when plugged in so far). It seems to only trigger when using Nomad.
I have a similar GPU to you, a GTX 1660 Super. I know it’s a bit long in the tooth, but it’s held up for most things at 1080p. Maybe the problem is with the 1660 graphics cards? I’ve tried everything I can think of, disabling VSync in Nomad seems to reduce the occurrence, but it still happens, just not as often.
Thanks for getting back, not sure why it’s happening on my system, my Windows 11 is fully up to date as of today. Maybe you could help me out if you can answer a few things:
Is it plugged in, or are you using Bluetooth?
Do you have Hardware-Accelerated GPU Scheduling turned on in the Windows 11 graphics settings?
Do you have VSync on or off in Nomad? Do you have a GSynce monitor?
Just trying to find a pattern @Emer has a very similar graphics card to me, but you had the problem with a 4070, so maybe it’s not just the 1660 cards.
Hey man, I basically installed Nomad and was running it on the default settings and my entire pc crashed. Mine is a pretty good pc and I have a xp pen display tablet. I dont think the tablet matters much as all the xp pen tablets use the same driver unlike other tablets.
