Would be great to have a camera/rotational border around the edge of the screen for when you are zoom in close. Right now if you are zoomed into the model so the the model takes up all the screen, there is no place to navigate the camera and you have to zoom out to do so.
If you have the View Cube enabled you can use it to rotate your view while zoomed in.
Also, you can set it up so that your fingers navigate and stylus sculpts. This will allow you to rotate while zoomed without issues
Awesome. That totally works. Thank you.
