ohhh wonderful! like the the mix of stylized and real!
The bricks on the corner, how you created it? an alpha and painted?
Thanks!
The bricks are combination of alpha and painting. Brick area is with higher mesh density.
How you add selective density to specifics areas?
When painting/sculpting enable Dynamic topology.
You’ll probably have to do some tests to find appropriate value/resolution.
You cam mask out areas that you don’t want higher mesh density before starting.
Awesome! This is best building done in Nomad I‘ve ever seen.
So, if I add alphas in some areas mask off the areas and using dyntopo add the alphas?
Wrote a quick tut here how it could be done. Just one option.
Yes, that’s basically it.
Thank you for your kind words and nice tut!
Looks great, add some position lights and you have an 50’ UFO
Like to see how this ends up.
Cool rendering! Looks fantastic.
What about the monolith from 2001 space odyssey, instead of just a cube?
The evil default cube
Very nice details
Looking good!
Yes, in material turn the surface glossiness in override painting to 0. Then you can control the roughness in the normal paint surface settings.
