Hi. Newbie here. When I’m working on an object, and import something else, they end up being quite a distance from each other. How can I make sure I import something into the same area I’m working on?
Imported objects generally keep their position in world space.
When you start a project in Nomad, you start sculpting at world center.
If you want your part to import next to your nomad parts (world center) then make sure your part is located at, or as close to, world center in the other software or project before exporting it.
Brilliant! Makes perfect sense thanks
