More control over line / arrow widgets
It wo I ld be very helpful to have thicker lines, arrows etc with regards to the gizmo and other items like nodes and vertexes.
Maybe a setting, like scale, that can allow the user to set the size/ thickness for there finger, stylus etc. In my case, on Android, my stylus ppin needs to be dead on in order to select the size or rotate rings.
I gave adjusted the available settings but they are limited to how big you can make the gizmo.
At least for the gizmo you can! Thickness, size and opacity options. For the others you might need to enlarge the ui however.
Yes I have used those but the thickness is limited to 100.
I have changed my tablets di as play settings. That helped but it affects all apps. Not tge best option.
